Guest Posted October 28, 2012 Report Posted October 28, 2012 I want to transfer a program of FX3U PLC or any other Q-series PLC and I am connected to Q PLC through RS232 and Both PLC is connected through CC-ink. Is it possible to transfer the Program or monitor the Program of any PLC connected through CC-link ? If yes then please tell me setting in transfer setup.
kaare_t Posted October 28, 2012 Report Posted October 28, 2012 Don't remember if you can do it with the FX but Q sure works.
Crossbow Posted October 29, 2012 Report Posted October 29, 2012 I was told FX3U-16CCL-M has this feature as well, but the old FX master did not. I have not ever tested it.
Guest Posted October 30, 2012 Report Posted October 30, 2012 I had tested with FX3U 64CCL-M Via Q00J CPU (QJ61BT11N) but on connection test it get failed. May be i had inserted wrong Head I/O no., I will try this tomorrow.
Guest Posted October 31, 2012 Report Posted October 31, 2012 (edited) I had tested with FX3U PLC i found following setting for communication from Q PLC to FX3U through CC-link Setting for Transfer Setup of FX3U Remote PLC Transfer Setup>>PLC Side I/F>>PLC Module>>PLC mode:-QCPU(Qmode) should be selected. Setting-1.bmp After that Set Head IO no. and Station no. setting-2.bmp Edited October 31, 2012 by Majid
Crossbow Posted October 31, 2012 Report Posted October 31, 2012 Majid, there is no such thing as FX3U-64CCL-M. 64CCL is NOT a master its a slave. No -M on it.
Guest Posted November 1, 2012 Report Posted November 1, 2012 (edited) sorry for wrong comment, Thanks Crossbow for correction, the module FX3U-64CCL in our assembly line project with all FX3U PLC has been used as Slave Module. Edited November 1, 2012 by Majid
