Edy Posted November 12, 2012 Report Posted November 12, 2012 I have a PLC CP1L-L29DT-D and I'm trying to send pulses through the instruction @ PLS2 (887) to a stepper motor driver Wantai DQ860MA. And I am not succeeding would like to help me please. Driver's specifications are as follows: http://www.wantmotor.com/ProductsView.asp?id=271&pid=82 Quote
PMCR Posted November 21, 2012 Report Posted November 21, 2012 What specifically is not working? Do the LEDs on then outputs of the CP1L appear to be turning on when you command by PLS2? If so, then it is most likely a wiring problem or setup of the stepper. If the outputs are not turning on, then it is a programming problem. Quote
edpuente Posted January 12, 2013 Report Posted January 12, 2013 Not only consider the puslses but also if its a NPN or PNP connection. The wiring of the PLC would be different depending on it! Quote
ngocthien Posted February 1, 2013 Report Posted February 1, 2013 I'm doing use pulse out to driver of step motor too, I use the ACC instruction to pulse out and INI instruction to Stop , if you use INI instruction then step motor will be stop sudden! Example: pulse out.bmp Quote
Sergei Troizky Posted February 1, 2013 Report Posted February 1, 2013 (edited) Yes, and this is exactly what the immediate stop INI instruction should do. So what is your question? If you want to decelerate to stop, execute the ACC instruction again, with desired deceleration rate and zero target speed. And why are you using hexadecimal values, not decimal ones? Edited February 1, 2013 by Sergei Troizky Quote
