Nkiritsis Posted November 15, 2012 Report Posted November 15, 2012 Dear All I have the following setup 1. Schneider Electric PLC TWDLCAE40DRF programmed in TWIDo 2. Schneider Electric Magelis XBTGT 2330 screen on which i use to represent my process and view my results. I used vijeo designer for this I can see the results on MAGELIS and i can even make graphic charts while my process is running. This means most probably that my data is stored somewhere in the MAGELIS memory. I must store all this data logging on a cf card and later on to convert to file able to open on any PC (but not to be able to modify the file on the PC) My problem is that when i try to store to the CF card (schneider MPCVNooCF 400N...4gb) i get the following message. 'VARIABLES ARE BEING LOOGED TO THE STORAGE VOLUME , WHICH IS NOW UNAVAILABLE OR FULL.-DATA LOGGING' I did follow all the isntructions described in vijeo help, i did format the cf card to FAT32 format and insert it again on the screen. Which means that the card is for sure formated correctly and is completelly empty. Still the message is the same 'VARIABLES ARE BEING LOOGED TO THE STORAGE VOLUME , WHICH IS NOW UNAVAILABLE OR FULL.-DATA LOGGING' Tring to find out what goes wrong i have tried also the vijeo data manager. There you can select option of exporting either to secondary drive (cf card) or to main drive. I tried both options and got 'CANNOT ESTABLISH CONNECTION' message. Any ideas? i am stack THANKS FOR YOUR TIME
