Daveinarmstrong Posted November 16, 2012 Report Posted November 16, 2012 (edited) Hello, I am using GX Developer version 8 with Mitsubishi FX2n PLC. Can anyone tell me how to write a value to D700? the value will be 20000. thanks in advance for your help. Edited November 16, 2012 by Daveinarmstrong Quote
Gambit Posted November 16, 2012 Report Posted November 16, 2012 (edited) MOV K2000 D0 Via the software: Online Debug Device test Edited November 16, 2012 by Gambit Quote
Daveinarmstrong Posted November 16, 2012 Author Report Posted November 16, 2012 Thanks Gambit, I'm not connected to the PLC until tomorrow to try this out. After i go into device test, do i just type in MOV K2000 D0? Quote
Gambit Posted November 16, 2012 Report Posted November 16, 2012 (edited) Just Press Set Edited November 16, 2012 by Gambit Quote
Crossbow Posted November 16, 2012 Report Posted November 16, 2012 The MOV command is for coding into your program. Gambit showed you how to use device test. Quote
