Stuartjl Posted December 3, 2012 Report Posted December 3, 2012 (edited) Hi, today i connected to our Q-series plc and tried to go into monitoring mode but got this warning "no binary, POU, DUT found" also when i verified the project i got a similar message. I definitely know there's code on the plc as it runs. Can anyone tell me why this is? As im trying to go online. Stu Edited December 3, 2012 by Stuartjl
kaare_t Posted December 3, 2012 Report Posted December 3, 2012 It's probably because your program on the computer is not compiled (without errors). Since it is not compiled, GX IEC has no binary code for it. The problem however is that if you compile the program you will have two different compile times, hence you cannot verify the program in the PLC and the program on your computer. 1
Stuartjl Posted December 4, 2012 Author Report Posted December 4, 2012 (edited) Hi, thanks for the response. I built the code with no errors, then i did a rebuild all. The compile was cancelled due to number of warnings, this code is current. So not sure whats going on Warning in NW32: C9131 The bit output function EQ_E is changed in every case because the project specific option to SET/RST is not set. Edited December 4, 2012 by Stuartjl
kaare_t Posted December 4, 2012 Report Posted December 4, 2012 Ekstras -> Options See picture to increase allowed number of warnings. 1
Stuartjl Posted December 4, 2012 Author Report Posted December 4, 2012 I knew it was somewhere, thanks :)
