Dan Landers Posted January 9, 2013 Report Posted January 9, 2013 Does an AB PLC support the Get_Member or Set_Member services? (Also included is the Insert_Member and Remove_Member services?)
Ken Roach Posted January 9, 2013 Report Posted January 9, 2013 ControlLogix can do pretty much any CIP message using the MSG instruction. Typically I've found when I want to read and write to assembly members that it's the end device whose support is questionable. What is the device that you're sending messages to ?
