Heloo, I have a problem . i wanted to start the CX-SP Run-time today , and i see that the runtime is not loading , it remains white. I log on . i can chek everithing but the screen remain white. Edited by Royal911
Does it do this if the 30 day trial has run out? Probably have to check that with Omron.
Sounds like there is a message box behind the screen. Try pressing the "Alt" key to bring it to the front or Alt-Tab to find it. If it is an error message hopefully it will explain the cause of the problem !! BB Edited by Berti Baker
Hi Berti, I got typical problem with Runtime execution, post completed the page with Developper, I called up the Runtime to test it, however, the Runtime was executed for secs only, showed up with small incomplete CX Supervisor window at left upper on the loaded page, and aborted by the system itself. I have logged in as Admin user. Do you have any idea with this matter? Thanks.
