Hallo. I have an array[1..10] of DUT where i save data for every time an operator empty a box full of sorted boards. Another operator receives the boards later on, and create a pack. When the first operator empties the box, i move the data into the first available array. The second operator don't necessarily use the first entry in the array. When the second operator uses or delete one of the arrays(packs), lets say [3] entry i then move entry [4] to [10] to place [3] to [9]. Basically i want the data to be topmost in the array at all time. I have made this with A LOT of MOVE_E functions, and it works. But i wondered if there was a smarter ways to do it. If i had to expand the array to 20, i would had to add hundreds of MOVE_E functions. Any ideas? I'm working with iec developer 7,04 The picture below shows how i check on array 1 and 2. I have checks for array 3 to 10 below(no room in screenshot).
I'd look at using structured text. The following example is similar to your request but not identical. I'm just using an array of signed word rather than DUT. Make moved equal to the moved "pack" and then all packs below that one will be moved up one and pack[0] will be zero'd. This was done in GX Works2. ----------------------------------------------------------------- (*fill array with some data on first scan*) IF M8002 THEN pack[0] := 10; pack[1] := 20; pack[2] := 30; pack[3] := 40; pack[4] := 50; pack[5] := 60; pack[6] := 70; pack[7] := 80; pack[8] := 90; pack[9] := 100; moved := -1; (* -1 means do nothing*) END_IF; FOR index := moved TO 1 BY -1 DO; lower := index -1; upper := index; pack[upper] := pack[lower]; END_FOR; IF moved > -1 THEN pack[0] := 0; moved := -1; END_IF; Edited by Veganic
