List of application and engineering examples for SINAMICS
Hello SIMATIC and SINAMICS Users, Now, there is a Page available, which shows you all application and engineering examples for SINAMICS G, SINAMICS S, SINAMICS V and other drives. The sample applications provide: - Reusable blocks for scaling the setpoint and actual values - Explanation of the configuration steps with screenshots - Reliability through previously tested programs and blocks for parameter access - Significant reduction of commissioning time - Detailed described documentation with parts lists of the used hardware and software items You can set the filters in combination with drive type, PLC, communication type between drive and PLC, drive function and so on. Try and visit the new web page for free downloads. http://www.siemens.com/sinamics-applications www.siemens.com/sinamics-applications
Now it's available SINAMICS S: Positioning of a S120 using S7-300/400 (STEP 7 V5) with PROFINET/PROFIBUS, Safety Integrated (not via PROFIsafe) and HMI. The application shows you the positioning of several axes of a SINAMICS S120 with PROFINET or PROFIBUS connected with a SIMATIC S7-300. The safety functions of the SINAMICS S120 are controlled via terminals. The FB283 for EPOS control and a HMI for user control is used. You can donwload the application here Link. Here you can find all applications for SINAMICS S120 Link.
Now it's available SINAMICS G: Speed control of a G120 using S7-300/400 (TIA-Portal) with PROFINET/PROFIBUS and Safety Integrated (not via PROFIsafe) and HMI The application example shows you the control of a SINAMICS G120 with PROFINET/PROFIBUS using a SIMATIC S7-300 PLC in TIA-Portal. You can download the application example for STEP-7 V11+SP2 or STEP-7 V12. Here you can find the application exampleLink. All application examples for SINAMICS G120 you can find here.
The application examples for the new SINAMICS CU250S-2 are available now. SINAMICS G: Positionig a G120 CU250S-2 with S7-300/400 (STEP 7 V5) via PROFINET/PROFIBUS using Safety Integrated (via PROFIsafe) and HMI SINAMICS G: Speed control of a G120/G120C/G120D/G120P with S7-300/400 (STEP 7 V5) via PROFINET/PROFIBUS using Safety Integrated (not via PROFIsafe) and HMI You can find all SINAMICS G120 application examples here.
Now the application example is available SINAMICS G: Speed Control of a G120/G120C/G120D using S7-300/400 (STEP 7 V5) with PROFINET/PROFIBUS and Safety Integrated (via PROFIsafe) and HMI supplemented with the new CU250S-2 and FW V4.6
Hallo together, now is the application example to use the integrated web server of the SINAMICS S available. You can design a web page with drive parameters user defined SINAMICS S: S120 web server - Creating user-defined web pages And here a collection of helpful SINAMICS S120 DCC application examples SINAMICS S: S120 DCB library “GMC” for Motion Control Applications SINAMICS S: S120 Camming with DCC SINAMICS S: S120 1:1 Synchronism with DCC SINAMICS S: S120 Gearing and positioning with DCC SINAMICS S: S120 Gearing with DCC
Hello SINAMICS HVAC Users, there are three new applications with SINAMICS G120P SINAMICS G: Fans for Closed-Loop Control of Exhaust Air SINAMICS G: Closed-Loop Control of a tunnel/car park fan SINAMICS G: Closed-Loop Control for a staircase fan For more application examples with SINAMICS G120 P, follow this hyperlink
Here the new SINAMICS application examples SINAMICS G: Speed Control of a G120 (Startdrive) with S7-1500 (TO) via PROFINET or PROFIBUS with Safety Integrated (via Terminal) and HMI SINAMICS G: Pressure controlled vacuum pumps Transforming message from a SINAMICS drive from XML format and displaying it in clear text with the help of the SINAMICS XML Parser SINAMICS V: Controlled Positioning of a V90 with S7?1200 via the Pulse/Direction Interface with HMI SINAMICS G: Speed Control of a G120 with Allen-Bradley controller (Compact/ControlLogix with RSLogix 5000) via EtherNet/IP SINAMICS G: Positioning a G120 (Startdrive) with S7-1500 (TO) via PROFINET or PROFIBUS with Safety Integrated (via Terminal) and HMI
There are new application examples with SINAMICS SINAMICS S: Speed control of a S120 via CANopen SINAMICS S: Time synchronization between S7-300/400 (STEP 7 V5) and S120 For use SINAMICS with SIMATIC (S7-1200 or S7-1500) in TIA Portal, you can use the function blocks SINA_Speed, SINA_Pos and SINA_Para Here you can download the DriveLib http://support.automation.siemens.com/WW/view/en/68034568
  • Like 1
For all EtherNet/IP user, here are an application example with SINAMICS S120 controlled via EtherNet/IP SINAMICS S: Speed Control of a S120 with an Allen-Bradley controller (Compact/ControlLogix with RSLogix 5000) via EtherNet/IP
  • Like 1
Here are the new SINAMICS application examples SINAMICS G/S: Generating GSDML-files for S120, S150, G130, G150 SINAMICS V: Speed Control of a V20 with S7-1500 and ET200SP via USS® Protocol, with HMI Connection SINAMICS G/S: PROFINET Connection to LabVIEW
