EJ1N-HFU-ETN - Profinet IO gateway
hi, This is the first time im going to use EJ1N-HFU-ETN Ethernet to serial gateway. can enybody explain me how this device going to power up (where i have to give the operating voltage?). before I purchase anything I would like to have your valuable advice. Thanks & Regards, Chinthana
This one stumped me for a while until I read the data sheet. "Use stand-alone with an EJ1C-EDUA-NFLK End Unit to connect RS-485 serially to MX2 AC Drives, E5?N Temperature Controllers, and other Modbus devices for a low cost gateway to PROFINET on Ethernet cable." Be sure to download all references found in the datasheet. EJ1N-HFU-ETN_DataSheet.pdf EJ1N-HFU-ETN_InstructionSheet.pdf
