tonehunta Posted February 28, 2013 Report Posted February 28, 2013 Hey! I've been programming a CJ2M Omron PLC plus a NQ5-MQ000-B Console using the CX-Programmer and its Function Blocks. The thing is that I've got some problems around the FB. As shown in the image below for the "ReadActualPosition" FB all I wanted was to show the value of the rotation velocity of the motor (once I put "&4" as "MonitorType" input value) in the output named as "Monitor" which I used the DINT (32bits) "W450". You guys can check out the .pdf associated to this FB, so just click here: http://chomikuj.pl/orzech777/OMRON/O...1383011634.cxf If you guys can fill me in, I'd be very grateful plc2.zip
james_applied Posted March 15, 2013 Report Posted March 15, 2013 OMITUNISIA No need to shout caps are very bad manners and likely to get you ignored. tonehunta See if you can speed read out or calculate the change in actual position over time to give speed.
