Koyo Kostac Programer
Guest Max fdp
Hi, all Good day. I need your Helping. I want to change a value of a counter from 10 count into 2 count on PLC KOYO KOSTAC using the programmer SA-20. I cannot find any manual in the net. How is the key stroke procedure. or any body can find for me a web page that I can downloaded the manual for the Programmer. I really needed. Thanks a lot. warm regard. Max.
Guest Max fdp
I revise the information above. The PLC is KOYO KOSTAC SA-10R-EX And the programmer is A-21P-EX. Thanks. Max
Hi Max fdp ! The programmer is A-21P-EX can use for KOYO KOSTAC SA-21 ? Please see picture. thanks you !
Hi all ! The programmer is A-21P-EX can use for KOYO KOSTAC SA-21 ? \*PC-PGMSW : DIRECTSOFT PROGRAMMING S/W F ALL DL PLCS 32BIT Which capable (order number) to connect PLC with PC ? \*D3-DSCBL-2 : PC PGMING CABLE 330/330P/ 350 DL405 BTM PORT \*D3-232-DCU : RS232C DATA COMMUNICATIONS UNIT I must use 2 products for its ? see you ! Hoai THi
Hi everybody, I have an old PLC SA-10R-EX. Please tell me the mean of inputs 15 CNT and 16 RST(reset)?? Thanks
