xcoder Posted May 17, 2013 Report Posted May 17, 2013 hi how are you all i have a serious problem here i got ns5 omron v2 with touch panel problem the program is good and system is good then we purchased a new one i pulled out the memory card from the old one put it on the new ones all right program is running normaly nothing wrong then i tryed to copy the old memory card incase if something goes wrong when i wanted to read it on the computer its stared acting not normal files are corrupted all the program are corrupted so i recovered the files now when i put it on the ns5 it says ERROR No. 10: File System Error: Please recover the system program. ok i did some research i tried to make recovery by copying the files that comes with cx-designer but nothing works it doesnt work it doesnt update dont do nothing same error ERROR No. 10: File System Error: Please recover the system program. so i got the manual in how to update or do recovery they said something i didnt uderstand """"5. About Memory Cards 5.1 How to Format a Memory Card To use this program to update or recover your NS, do not format a memory card on a computer that Windows2000 SP2 or later, Windows XP , or Windows Vista is installed. Programs cannot be read and execution cannot be completed normally. This symptom is caused by changing specification of operation system on the computer to support large capacity hard disk.""" from that we understand that we dont have to formate it on a newer os like xp 2000 nt or 7 or windows 8 ok but where the hell we gonna formate it !!!! win98 !!!!?????? and when i want to recover using usb cable nothing no detection it does even pop up on new materiel detected by windows xp so please help me if you have any idea !!!!!! i will be fired if i dont fix that problem by the way i dont do automated stuff im just hardware technicien !!!!!! so please !!!!!!!!!!!!!! Quote
Mendon Systems Posted May 17, 2013 Report Posted May 17, 2013 (edited) That problem happens occasionally. It could be a bad card, or a bad NS5 terminal. That is why I stopped using them. As far as I know Windows 98 is the newest system you can use that will format a memory card for FAT16. The alternative is to get a new card from Omron. I have purchased some Sandisk Ultra CF cards in the past that came pre-formatted with FAT16. Edited May 17, 2013 by Mendon Systems Quote
pfort Posted May 17, 2013 Report Posted May 17, 2013 I remember have formatted CF card with an old camera. Quote
RickyQ Posted May 20, 2013 Report Posted May 20, 2013 If you happen to have an omron PLC around, you can format the card with cx-programmer if you plug it into the omron CPU. Quote
Ribeiro Posted August 20, 2020 Report Posted August 20, 2020 On 17/05/2013 at 15:09, xcoder said: oi como estão vocês eu tenho um problema sério aqui eu tenho ns5 omron v2 com problema de painel de toque o programa é bom e o sistema está bom então nós compramos um novo eu retirei o cartão de memória do antigo e coloquei nos novos tudo certo programa está funcionando normalmente nada de errado então eu tentei copiar o cartão de memória antigo no caso se algo der errado quando eu queria ler no computador ele começou agindo não normal os arquivos estão corrompidos todos os programas estão corrompidos então eu recuperei os arquivos agora quando eu coloco no ns5 ele diz ERROR No. 10: File System Error: por favor, recupere o programa do sistema. ok eu fiz algumas pesquisas que tentei fazer a recuperação copiando os arquivos que vem com o cx-designer mas nada funciona, não funciona, não atualiza, não faz nada mesmo erro ERROR No. 10: File System Error: Por favor, recupere o programa do sistema. então eu peguei o manual de como atualizar ou fazer a recuperação, eles disseram algo que eu não entendi "" "" 5. Sobre os cartões de memória 5.1 Como formatar um cartão de memória Para usar este programa para atualizar ou recuperar seu NS, não formate um cartão de memória em um computador com Windows2000 SP2 ou posterior, Windows XP ou Windows Vista instalado. Os programas não podem ser lidos e a execução não pode ser concluída normalmente. Este sintoma é causado pela alteração da especificação do sistema operacional no computador para suportar o disco rígido de grande capacidade. "" "A partir disso, entendemos que não temos que formatá-lo em um sistema operacional mais recente como xp 2000 nt ou 7 ou Windows 8 ok, mas onde diabos nós vamos formatar isso !!!! win98 !!!! ?????? e quando eu quero recuperar usando o cabo usb nada sem detecção ele faz até mesmo aparecer em novo material detectado pelo windows xp então por favor me ajude se você tiver alguma idéia !!!!!! Eu serei demitido se eu não consertar esse problema pela maneira como eu não faço coisas automatizadas, sou apenas técnico de hardware !!!!!! então por favor !!!!!!!!!!!!!! alguém tem a resposta para este problema? a ihm omron ns10 tem um cartão que fica embaixo da placa que é de inicialização da IHM, eu fui tirar ele pra tentar copiar e resolver um problema de outra IHM e acabei ficando com as duas sem funcionar. Acontece o que o amigo disse ai, so de ligar a ihm aparece erro 10 file sytem error. Ja pesquisei de tudo, ja tentei formatar o cartao em varios formatos, usei camera fotografica pra formatar, tudo!!! formato e coloco o arquivo recovery do cx designer , mas nao funciona. Alguém tem a soluçao, me ajudem por favor!!! Quote
Ribeiro Posted August 20, 2020 Report Posted August 20, 2020 On 19/05/2013 at 07:12, xcoder said: obrigado galera ajuda bem ola, voce conseguiu resolver esse seu problema na epoca? estou com o mesmo problema aqui. Quote
vasekd Posted August 21, 2020 Report Posted August 21, 2020 You have to buy new CF card (max 1 GB) and use it without any formating (never format this card). Quote
Ribeiro Posted August 21, 2020 Report Posted August 21, 2020 Vasokd .. and use the cx designer recovey update file? Quote
Ribeiro Posted August 21, 2020 Report Posted August 21, 2020 this update file only works if the HMI initialization is working. or am i wrong? Quote
vasekd Posted August 21, 2020 Report Posted August 21, 2020 Yes: https://www.myomron.com/downloads/4.Products/NS%20Firmware/NS_V8.65/HowToRecoverUpdate_Eng.pdf Quote
S1090 Posted December 2, 2023 Report Posted December 2, 2023 On 17/05/2013 at 11:39 PM, xcoder said: hi how are you all i have a serious problem here i got ns5 omron v2 with touch panel problem the program is good and system is good then we purchased a new one i pulled out the memory card from the old one put it on the new ones all right program is running normaly nothing wrong then i tryed to copy the old memory card incase if something goes wrong when i wanted to read it on the computer its stared acting not normal files are corrupted all the program are corrupted so i recovered the files now when i put it on the ns5 it says ERROR No. 10: File System Error: Please recover the system program. ok i did some research i tried to make recovery by copying the files that comes with cx-designer but nothing works it doesnt work it doesnt update dont do nothing same error ERROR No. 10: File System Error: Please recover the system program. so i got the manual in how to update or do recovery they said something i didnt uderstand """"5. About Memory Cards 5.1 How to Format a Memory Card To use this program to update or recover your NS, do not format a memory card on a computer that Windows2000 SP2 or later, Windows XP , or Windows Vista is installed. Programs cannot be read and execution cannot be completed normally. This symptom is caused by changing specification of operation system on the computer to support large capacity hard disk.""" from that we understand that we dont have to formate it on a newer os like xp 2000 nt or 7 or windows 8 ok but where the hell we gonna formate it !!!! win98 !!!!?????? and when i want to recover using usb cable nothing no detection it does even pop up on new materiel detected by windows xp so please help me if you have any idea !!!!!! i will be fired if i dont fix that problem by the way i dont do automated stuff im just hardware technicien !!!!!! so please !!!!!!!!!!!!!! Hi there I am facing same problem, i accidently formatted internal 128 MB card in windows 10 then i realized my mistake and bought 2 new cards 1 is 128 mb for internal memory and 2nd one 1 gb for update recovery program. I never formatted these cf cards till date but i am unable to restore my NS 12 PT. After inserting external memory card with recovery program files green light on and then nothing happened. I also tried to on DIP switch 6 several times but nothing happened. If anyone have solution please reply asap. Quote
IO_Rack Posted December 2, 2023 Report Posted December 2, 2023 NS Recovery - CX-Designer - Forums.MrPLC.com Quote
