mhi Posted May 30, 2013 Report Posted May 30, 2013 Dear All, Do anybody know which instruction in S7 300 programming which can be use for 'Sequencer Output'? This 'sequencer output' will function similarly like RS logix 500 'SQO Instruction' which is used for transfer 16-bit data to word addresses for the control of sequential machine operations. Thank you. Best regards, MHI
Groo Posted May 30, 2013 Report Posted May 30, 2013 I would normally write my own, there is a library instruction called 'Drum' which I believe is in the TI conversion blocks.
minetsky Posted July 26, 2013 Report Posted July 26, 2013 Im not 100% understand what you mean but you might wanna try the shift register function :)
