wal Posted June 4, 2013 Report Posted June 4, 2013 Hi to everybody. Don't know why, but the help was not installed automatically on GX Works2. When I press F1, instead of help an advise to install the help only. I put original DVD disk and started installation. There was no options like, "Install help". Why the help was not installed? What did I wrong? How can I get help installed? regards, Wal
Goody Posted June 4, 2013 Report Posted June 4, 2013 At a quick guess - you have probably got the help feature disabled in windows. Either a service or something else. Not in gxworks, but windows
wal Posted June 4, 2013 Author Report Posted June 4, 2013 Thank You Goody, as I understand the help means a special file nested somewhere in computer. Where shoud I look for it? Where is the control for the Windows Help feature?
Crossbow Posted June 4, 2013 Report Posted June 4, 2013 You mean the help for FX PLCs? That's in a different directory on the original DVD and needs to be added from there. The rest of the help is built in. Just the FX F1 help is not, as it comes from a different factory than the software.
wal Posted June 5, 2013 Author Report Posted June 5, 2013 Thank You Crossbow for the answer. I mean help for GX Works2 when the button F1 pressed. For the project FX3U is used. What should I do to get help (not an error message, like now)? What is the name and extension of the help file, *.chm, *.hlp or something different? Where must be it placed? Where to get it?
djtron Posted June 5, 2013 Report Posted June 5, 2013 If I push F1 I get this: Did you try "Help" and then "GX Works2 Help" from the menu bar?
Crossbow Posted June 5, 2013 Report Posted June 5, 2013 As I said, FX help is separate. Browse the DVD for a directory called DocFX and run the setup file. This is documented in the manual for GX Works2. 1
ta2mix Posted January 25, 2021 Report Posted January 25, 2021 I have a new question. When I run gx works2 v1.98 c F1 help For example, pressing the F1 button while on TON-1 opens the page about the TON time relay. Now the general help book is opening how can i fix this
