Is there anyway in VersaPro software to check or scan for overrides that have been set in the PLC? Sometimes I set an override and forget to go back and release it. It would be good if VersaPro would tell you if there are some that still exist or if there is a way to release them all. Any pointers?
The status bit %S0011 (OVR_PRE) is on whenever an override is active. In addition there is Service Request #18, but that only checks the %I and %Q tables for overrides. Unfortunately, there is no blanket "Clear all overrides" command.
