Jaakko Pasanen Posted July 31, 2013 Report Posted July 31, 2013 Hello World! I created PLC friendly code for Fast Fourier transform (FFT) on IEC-61131-3 Structured text called StFFT. Program code is freely available on SourceForge. Code is licenced under both open source LGPL and Commercial licence. I couldn't find FFT implementation on PLC anywhere, so I decided to write one myself. Actually I could hardly find any mention about FFT on PLC and certainly not anyone implementing one. StFFT is made with minimal system dependencied on mind, it doesn't use recursion and only needs sine and cosine functions to work. This means that it should be usable on just about any PLC available. For those who don't know what FFT is and where it is used, i recommend taking peek in the Wikipedia. FFT has many applications, we are using it in low-pass FIR filter for analog measurement on PLC without needing any external hardware. I hope somebody has use for this... - Jaakko Pasanen
Sleepy Wombat Posted August 6, 2013 Report Posted August 6, 2013 Hi Jaakko, Thanks for the info on the FFT. Most people on the forum would not have been taught FFT in their education, and I have never thought of the use of them beyond frequency isolation in communication systems with FSK, AFSK in mind for data protection on radio comm's/ mobile phones etc. Not sure of what you are trying to achieve with the of the application of a FFT on a Low Pass Filter for analogue signal... Are you trying to eliminate noise ?
Jaakko Pasanen Posted August 8, 2013 Author Report Posted August 8, 2013 Noise elimination is exactly what the low pass filter is doing in our case. I'm not talking about just white noise since that's not usually much of an issue, but eliminating higher unwanted frequency components like process induced vibrations might be critical for some applications. Of course usage of FFT isn't limited to low pass filtering, applications are numerous. However problem often is with PLCs' computing power: using FFT with as small as 256 elements might take tens if not hundreds of milliseconds. Whether that is a problem is completely dependent on the application and its requirements.
mjrx Posted March 4, 2015 Report Posted March 4, 2015 I was going to start playing around with this code, I'm interested in turning raw vibration accelaration data into freq spectrum for analysis. Just glancing at the code, there appears to be variables in the code that are not defined in the Symbols .pdf. In code, w_complex, I assume this is w_imaginary, same for code has x_complex and tmp_complex, .pdf has x_imaginary and tmp_imaginary. Since I need to update this spectra trend alot, and it seems very CPU intensive, what would the effect be if I modified the code to eliminate the for and while loop, simulating the for/whiles but doing it during the PLC scan (like just decrementing or incrementing the variable and exiting the FB, so I don't get hung up in the FB)? 1
MastrUsr Posted October 14, 2016 Report Posted October 14, 2016 I can't find this program/code, can anyone point to it? Thansk! Eric
pop29684 Posted October 14, 2016 Report Posted October 14, 2016 I found it. Use the search term, "jaakko pasanen".
Michael Lloyd Posted April 1, 2017 Report Posted April 1, 2017 On 3/3/2015 at 10:09 AM, mjrx said: I was going to start playing around with this code, I'm interested in turning raw vibration accelaration data into freq spectrum for analysis. Just glancing at the code, there appears to be variables in the code that are not defined in the Symbols .pdf. In code, w_complex, I assume this is w_imaginary, same for code has x_complex and tmp_complex, .pdf has x_imaginary and tmp_imaginary. Since I need to update this spectra trend alot, and it seems very CPU intensive, what would the effect be if I modified the code to eliminate the for and while loop, simulating the for/whiles but doing it during the PLC scan (like just decrementing or incrementing the variable and exiting the FB, so I don't get hung up in the FB)? Old post but I have a similar need. Did you get this to work?
Wedo Posted February 16, 2018 Report Posted February 16, 2018 Hello mjrx, I am working on similar topic, converting raw vibration acceleration data into frequency spectrum on Siemens PLC. I am interested to know the result of your analysis. Is it successful? If so can you share the code? Thanks,
