Setting user range in analog module L60DA4
In the project tree you will go to intelligent function module, right click and select new module. Select the L60DA4. Now in the tree you will have the module and you can change the switch settings to whatever you desire. I will attach a screenshot.
Thanks plcdp. But there isn't required in my application output range 0-10V. So I set "user range" and my question is...what to do next.
What's the problem with plcdp's reply? What are you trying to do since that won't work (setting 0-10V scale)? Do you have some more information about what you are trying to do?
If you are looking for the range to say exactly 0-10 volts, it doesn't. You would set it up as -10 to 10vdc. (see attached screenshot) Positive voltage moving the actuator in one direction and negative moving it the other. Hope this helps, Dave
