Hi everyone. I am having troubles trying to figure out why I can not do any online edits with my Q03UDECPU PLC and GX Works 2 software? Any ideas guys?
If you are in monitor (write) mode, you should be able to make your changes and then press shift-F4 to perform an online write. Should be pretty straight forward. Dave
Isn't there an option when installing mitsi software to allow monitoring only. - Or can you edit online with other plc's?
I can monitor and online edit with other plcs in the plant. Same series plc and same software on the same laptop however the only difference is its simple ladder and in GX developer.
Have you checked the options menu under tools? Under the Program Common Tab there is an "After Conversion Writing Behavior" where there is a radio button to 'Write during RUN (while PLC is Running).
The topic starter clearly statet that this specific project was structured ladder, so my previous statement still stands. In structured ladder you don't go into "Online Change Mode", you simply change your program and press the button (commits the changes online).
My apologies kaare_t. I read the quote above and asumed my response. My picture attachment above is for GX Developer not GX Works2. But you are correct, online edits for structured programs can only be executed as you described previously in GX Works2.
kannappan, please make your own posts in the future.  This topic has nothing to do with GX Works3 and simulation, and it's over 3 years old.
