We have a Q03UDE using GX Works 2. Every time we read the PLC, it asks for the Intelligent Function Modules to be named. Wename them and then save but the attached message keeps coming back. Any suggestions on eliminating this? Thanks....
Well, in the picture it seems that the modules in your physical location does not correspond with the modules in your project. Is that correct, and isn't then the behaviour as it should be? If this is not the desired behaviour please describe a bit more how you would suggest it to work when there's differences in the PLC/GW2...
Well, it's easy to check if the parameters (modules) in the original project is correct by looking at the physical installation. The first question would be if they match.... Do they?
