prtbrown Posted September 11, 2013 Report Posted September 11, 2013 (edited) I need to set the midpoint of a PID function via sensor readings. The min and max are 0.7-1.0 hence I want to set the midpoint at 0.85. I want to use the Mov instruction to move a floating point number constant (0.85) into an UINT variable but I don't know how. Could I just set the midpoint at 85 and scale the sensor readings by x10? Edited September 11, 2013 by prtbrown
BobB Posted September 11, 2013 Report Posted September 11, 2013 If you are doing floating point maths and have to use constants you must use the FLT (32 bit) or FLTL (64 bit) to turn a constant into a floating point number.. If you wish to move a floating point number you can use MOV (16 bit floating point number into a 32 bit register) or MOVL (long move - 32 bit floating point number into a 32 bit register). Remember 32 bit floating point uses 2 registers (D) and 64 bit floating point uses 4 registers for each number - easy to forget and try to use adjacent D registers instead of allowing 2 Ds between each number.
Crossbow Posted September 11, 2013 Report Posted September 11, 2013 You can't store a number with decimal places in anything other than REAL (floating point) format. So you can't put 0.85 into a UINT. As you indicated, you can multiply the values by 100 (not 10) so 85 mean 0.85. Or you can convert the values all to floating point like BobB said. The Omron PLCs (you never said which model) should have support for floating point math, comparison, etc. so no reason not to use floating point for the extra accuracy of the decimal places.
pfort Posted September 11, 2013 Report Posted September 11, 2013 What did you mean by midpoint for PID function? Variables for PID instruction must be UINT.
Mendon Systems Posted September 11, 2013 Report Posted September 11, 2013 Another thing to note, he FIX function that converts FP to UNIT does not round the value so 0.85999 will result in 85 not 86.
BobB Posted September 11, 2013 Report Posted September 11, 2013 Yes, that is an annoyance. FIX and FIXL truncate the decimal part. I would like to see these functions at least shift the left over into another channel so that they can be accessed.
Mendon Systems Posted September 11, 2013 Report Posted September 11, 2013 Yep, it's a pain. The easiest fix is to add 5 to the first digit you don't use, in this case it would be +0.005.
prtbrown Posted September 12, 2013 Author Report Posted September 12, 2013 (edited) thanks for the replies. this is my first job working with PLCs (but learning quickly!) I am reusing code from another programmer. Under the PIDAT (191) instruction he has set the Setpoint Value as an operator input value (IDEAT1_PID_SV) which is an UINT. In the screenshot of the HMI the example input value is 7.2. For my present spec, I need to fix the setpoint at a value of 0.85. So my confusion is how do I set 0.85 as a constant in the PIDAT instruction? The CPU is a CS1G-H Edited September 12, 2013 by prtbrown
Geir Posted September 13, 2013 Report Posted September 13, 2013 There is probably some scaling involved, first you need to find the input range of the PIDAT itself. Look for a MOV that puts a HEX number like #1494 in the Setpoint + 6 address. IE if the setpoint is at address D3101, the range control parameter is in D3106. the second digit (from left) is the input range/resolution. 0 is 8 bits, 8 is 16 bits. 4 is a common value, that gives 12 bits resolution and a range of 0 to 4096. A setpoint of 50% would then be 2048. Geir
