Cimplicity MEdition & Viewstation download problem
Guest Meylin
Hi Somebody can help me,PLEASE I am trying download a project in the viewstation GE Windows CE IIx by Cimplicity Machine Edition, I only can download one file and it showme the error message 2381 that you are getting is a 'Unable to Create Files on Target' I have disk space in viewstation, I don't know what's happenning Thanks for your help
This is what the online help says: Possible Solutions: Check for the following on the remote target computer: Does the target directory have enough disk space for the install files? If not, remove any unused files on the appropriate drive. Are the Machine Edition directories shared on the remote computer and do you have the permissions to access them? Is Runtime already started on the remote computer? If so, close Runtime and reboot the computer. When the CE IIx is started touch the button to prevent the Runtime from starting, just closing it after it starts will not work.
Guest Cimplicity ME & Viewstation
You may need to delete the runtime files on the CEiix box. These are the files in the \FlashDrive\Runtime directory.
