Using a Siemens HMI with a FX2n
Guest Mike Skiles
Hello, I am trying to integrate a Siemens TP170B with an existing FX2n PLC. I have the Mitsubishi Driver installed on the HMI, and have even installed a FX2n-232-BD option card on the PLC to connect with the Siemens HMI. All of the cable connections are correct,and all of the protocol settings match on both devices( I have even changed both to various matching protocols,including Protocol 4,standard RS Instruction, varying speeds and control protocol,and have verified that the data registers for the serial settings are correct ) but I still cannot get the two to communicate.I haven't yet resorted to installing my protocol sniffer on the line to see what's happening,but that might be next. Does anyone know of some possible issues with this type of integration? Normally I would just toss the HMI and use a Beijers unit, however the majority of the hardware in this plant is Siemens,except for this one PLC,and given that the program is in raw ladder format and quite extensive, I'm not inclined to replace it. Any ideas? Regards, Mike Skiles
Guest btalbot
what is the driver you are using? is it for Fx or Fx2n? can you try going RS422 directly to the cpu port?
