antht Posted August 31, 2004 Report Posted August 31, 2004 I am working on a project involving a number of E150 HMI's. I am really struggling to find a suitable material to print the function key labels on. The strip that comes with the HMI is the only material that won't crease when putting it in but it is clear. Ideally I want a material with a white background that allows the printed labels to be seen easily. I have tried photo paper and laminated strips of white paper but these both crease when inserting into the tiny slot on the HMI. Any ideas? Quote
Guest btalbot Posted August 31, 2004 Report Posted August 31, 2004 P-Touch labels on the clear strip have worked. Quote
Crossbow Posted September 1, 2004 Report Posted September 1, 2004 I've used a thick paper stock we print line cards on without problems, also used transparency material with no problems. Quote
Guest Albert Fanakapan Posted September 1, 2004 Report Posted September 1, 2004 I have also printed on a transparency then cut it to shape with scissors. The trick is to cut the leading edge thinner than the body. Quote
antht Posted September 1, 2004 Author Report Posted September 1, 2004 I am going to give transparencies a go. I am confident the material will be stiff enough but my only concern is the background colour. I may try putting correction fluid on the reverse of the transparency after I have printed on it. Thanks for the ideas Quote
antht Posted September 1, 2004 Author Report Posted September 1, 2004 Sorted! Printed the labels onto normal paper. Cut the strips out 4mm x 120mm. Laminated them, cut them out 10mm x 135 mm. The trick to shove them into the tiny slot is to put the plastic strip you get free in the slot 0.5" and use this as a guide. This stops your label strip creasing as you push it through the slot. PERFECT. Quote
