Guest Guest_Wouter Posted September 1, 2004 Report Posted September 1, 2004 Is it possible to force an output of a FX1N plc ON, using Microsoft Hyperterminal? Then what would be the command to set for example output 1 ON? Does anybody know this command? Other commands are also welcome...
FNMdeJong Posted September 1, 2004 Report Posted September 1, 2004 Yes it is possible, you only need to know the used protocoll. And I think that is classified information. Maby someone will give it to you, but not from mitsubishi or any other distributor. Monitor the line with an protocoll analyser while you force the output with any software and you will see the command. succes.
panic mode Posted September 2, 2004 Report Posted September 2, 2004 check the download section for basic code sample.
Guest Guest Posted September 2, 2004 Report Posted September 2, 2004 Hello : What I am Understand Is that You Want To force on An output Of FX1n Plc So If You HAVE SOFTWARE OF MITSUBISHI YOU CAN DO IT BY IT HOW THE WAY IS THAT OPEN FXGPWIN EXE FILE LOAD OR MAKE UR LOGIC AND GO ON STATUS BAR MONITOR / TEST SECTION THEN YOU WILL SE FORCE ON/OF INSTRUCTION FOR fXIN WHICH IS VERY SIMPLE THANKS s.m.aLI
