Stevo Posted November 24, 2013 Report Posted November 24, 2013 Hi. I am trying to connect my seimens laptop to Mitsubishi FX PLC I need DB 25 male plug to FX PLC. Can anyone tell me how or where I can get one pls Thanks.
kaare_t Posted November 24, 2013 Report Posted November 24, 2013 You need the SC-09 cable from Mitsubishi (I do not recommend anyone from Ebay) since it contains a RS232<->RS422 converter on the cable (the FX port is RS422). You should contact your local Mitsu dealer...
pejscott Posted November 26, 2013 Report Posted November 26, 2013 (edited) Hi. You can make a purchase for the items you request from Amazon UK, from a online retailer called (SainSmart). They sale, cost effective alternative PLC programming cables for the Mitsubishi MELSEC FX. Personally, you should take the option, of using a (USB) port from your Siemens laptop to a RS422 adapter for the MELSEC FX PLC. Please, (Select) or (Paste and Go) to the following links: *. (*****RECOMMENDED*****) New PLC Programming USB-SC09-FX Cable For Mitsubishi MELSEC USB TO RS422 ADAPTER : http://www.amazon.co.uk/Programming-USB-SC09-FX-Mitsubishi-MELSEC-ADAPTER/dp/B007F93IQ2/ref=sr_1_1?ie=UTF8&qid=1385434695&sr=8-1&keywords=usb+to+sc-09 *. SC09 SC-09 Cable RS232 to RS422 adapter for Mitsubishi MELSEC FX & A series PLC *RED* http://www.amazon.co.uk/SC-09-Cable-adapter-Mitsubishi-MELSEC/dp/B007F93IXK/ref=pd_sim_sbs_ce_2 The manufactured programming cables are from a company registered as (JIACHENG), - Chinese manufacturer. For PLC Programming Cable USB Drivers and Video Tutorial Demonstration to Install. Please, (Select) or (Paste and Go) to the following links: *. http://www.plccables.com/drivers.html Hope this information is helpful. Edited November 26, 2013 by pejscott 1
kaare_t Posted November 26, 2013 Report Posted November 26, 2013 Well, as I previously stated; you should use a standard (Mitsu approved) SC-09 cable. Others before you have tried the approach above with more or less success, even on this forum: http://forums.mrplc.com/index.php?showtopic=25864&st=0&p=124092&hl=usb%20sc09&fromsearch=1entry124092 You may choose to do what you want, but remember that we cannot help you very much if you use non-approved products and run into problems....
