matias21033 Posted January 18, 2014 Report Posted January 18, 2014 Hi all, I have a Modicon M340 PLC with the following configuration: CPS2000 - P34 2030 - DDM 16022 I want to implement this communication set between PC and PLC: Visual Basic 2010 Express (app not programmed yet) - Modbus - TCP/IP - Ethernet II - P34 2030 PLC Processor I need some general advice and to know if the previously communication set is correct. My questions are: 1) Is enough the P34 2030 processor to establish an ethernet communication? or I need an extra communication module? 2) Is there a Modbus library for Visual Basic 2010? 3) Can I have also a web access to the PLC variables? 4) This communication can be simulated using Unity Pro or I need to have the PLC connected physically? Thanks in advance, Matías
billysmithde2 Posted January 19, 2014 Report Posted January 19, 2014 The simulator should work fine as a server, which is what you likely need as your program will generally be a client. You could do communications the other way, but most of the time SCADA or other visualization software is the client and the PLC is the server.
matias21033 Posted January 19, 2014 Author Report Posted January 19, 2014 Thanks a lot for the quick response!! I will try all you suggestions this week and comment again after that. Your regards, Matías
