Eugen Posted January 24, 2014 Report Posted January 24, 2014 Hello, I need some help with a older machine a Driam coater DRC 1600/1.25, Step 5 Siemens PLC. The program was lost due to a dead battery (I know) and the program loaded from EPROM does not work. Siemens technician has looked at the machine and the manufacturer OEM sent some 5 1/4 floppy's that can not be read. A data block seams to have configuration info DB14 is missing. Anyone out there has a program for this machine? Anyone has a Siemens Programmer PG675 to read the floppy's? Thanks for any help Eugen
Groo Posted January 24, 2014 Report Posted January 24, 2014 If the disks originate from a PG675 then they will be cpm format, not DOS. If you cannot find a PG675/685 you would need a later version of S5 that runs on a PC and someone who can convert the old cpm disks into the newer format. The PG675 had two floppy drives and no hard disk, the PG685 was a later version that had a hard drive and 1 floppy drive.
