Hi, I meet a situation that I would like to solve with yours help. On recipe screen, I select a recipe to view the values for elements. Then I upload the values from PLC to see what are the actual values. On the name field remain the name of recipe that I viewed before. If I want to leave the page, then a message ask If I want to modify the recipe that I seen before. If I choose YES, then the recipe will get the values read from PLC. The machine operator sometime is not enough careful and damage the recipe. Can be that prevented in a way? I attach a screen shot for this message. dekor.
Normally when I've used recipe's, I have a recipe edit recipe, this is not used by the process. It can be read into by the operator and transferred to a working recipe. So if the operator wants to change a recipe, he would go to the edit recipe, read in the recipe that he wants to change, make his changes and then if happy transfer those changes from the edit recipe to the working recipe. Another method is to put in a are you sure? question.
Hi Groo, thank you for your response. There are two dedicated screens. One for editing recipe and one for one for visualization of recipe. I have problems on recipe visualization scree. On the screen for recipe visualization is ask about saving ? Why? I consider that somewhere is a mistake. I understood something wrong about "edit recipe" screen and "view recipe" screen? No one else has an idea about mistake? dekor.
