What command used for compare of two floats? FX3U
i got crazy with this software, why do i have to select my cpu when the command list is not limited to the commands that run on this cpu? ok, my problem: i need to compare two float values for greater_equal... what command should i use? i am using the GE Command (and several others like LT or GT for comparing two floats) is this right??
1. Which software are you using? 2. Don't understand what you mean by "selecting" CPU, there are different instruction sets for different CPU's so when you start a new project you must select the CPU type (can be changed later) 3. Yes you are using the correct commands for GE, GT, LT, EQ and so on
