Hi!! I am confused right now with the packet structure in sending data to an external device (Markem printer). I need to send this data (attached file) to the printer to update variable data to be printed. I am planning to use Fixed Buffer with no procedure. Do I simply use the instruction ZP.BUFSND? given that I have successfully opened the port for the target device (using ZP.OPEN instruction)? I need your expert advise.
OK, Simple Ladder then? You have the correct instructions. EDIT: Just give the instructions a try, and get back if you have any issues. Edited by kaare_t
I just testes communication through fixed buffer.. First, I used open port instruction and it went out successfully. And then I tried to send full message to Printer, the first message I got a negative acknowledge (nAK) response, does this mean I am communicating already with printer but wrong message format only?
Check out Wireshark. Freeware. EDIT: I was just thinking a bit more about this and wanted to let you know some small facts. Note that if you want to monitor between the two devices you will need a hub, or a managed switch with mirroring capabilities. A regular switch will not work. This is because of the way a switch is made; it only forwards traffic to a destined MAC address on the specific port the MAC address is on, therefore communication between a PLC and a Camera will only find place on the two actual ports that they are connected and not any third port your PC is connected. Therefore, you can do one of the following: 1. Set up a good old HUB (a hub is not as intelligent as a switch, and simply sends a telegram out on all the ports, hence traffic will flow to your computer both from the camera and from the PLC) 2. Use a managed switch and set up port mirroring (in the way that you define that all ports should be mirrored to the port your computer is on, then traffic on all ports will be mirrored to the computer port and you will see all traffic) 3. Simply set up the PLC against your computer and see what the PLC sends. This way you will not be able to see communication in both directions simultanously, however you will see what the PLC is actually sending since you can receive it on your computer. In any way, no matter what software you use on your computer (Wireshark or other), the above is still valid. Edited by kaare_t
No, as I can understand from the manual this is actually a switch. I guess that the Asian guy's who wrote the manual wanted to use the expression "HUB" (sometimes also referred to as "Bridging", as the manual states), however it is indeed a switching device so it will act as a regular switch, hence not sending all traffic to all ports. Do you have anything old laying around? I don't think I've ever seen a HUB with 1Gbps capabilities, so a good old 10Mbit or 10/100Mbit would maybe work if it is a HUB.
There might be another method to intercept the communication between plc and device by using two networks cards in your pc. I assume you have one network card already. You could add an extra network card by using a cheap ethernet to usb "network" card (which will probably come in handy for other uses too, especially if your pc is already connected to an office network). Plug the plc and pc in a normal switch, plug the device into your usb network card and bridge them together in Windows. As such, you can intercept the traffic from plc to device in both directions using Wireshark on your pc. It sounds complicated but it isn't. I've used it on occasion for analysing profinet data between io-controller and io-device. However, if you need to intercept data regulary, a hub or intelligent switch would probably be easier. Edited by Mitsu
I will try to look for another Hub. But I am suspecting part of my message to the printer "Data Checksum", maybe you could help me translate it into ladder. I attached file including Packet structure and Header Checksum. I am confused on the Data Checksum calculation part.
What software do you use for programming this, and which language? EDIT: The reason why I'm asking is that this is the same CRC as ModbusRTU uses and I have some finished function blocks for this purpose but it requires either GX IEC Developer, GX Developer WITH LABELS (so that you can use function blocks), GW 2 with Structured Ladder or GW 2 with simple ladder AND LABELS (so that you can use function blocks). If not using any of these and you are familiar with C/C++/C#/VB you can just google CRC Modbus RTU and you'll get lots of hits and just check out the code and convert it to simple ladder if that's what you're using. Edited by kaare_t
Are you familiar with Structured Ladder or other programming languages like C/C++/C#/VB so that you can convert an example to simple ladder yourself? If not, you will need someone to do the job for you (I would say appr. 4 hours of work to do the program).
Import the .sul file into a structured ladder project and open it. Then you can see how it is done. This is from a programatic Modbus routine, and the library contains the CRC blocks. I couldn't upload the .sul file, so I added the extension .txt. Just remove ".txt" and you have a .sul file. ModbusFXMaster_V100.sul.txt
