Crossbow Posted September 7, 2004 Report Posted September 7, 2004 I am looking for Java Beans which can be used on a Modicon Quantum 140NOE77110 webserver module. The factory set is not allowing me one simple object I NEED to create. My need is this: Text display based on a word input similar to factory MESSAGE DISPLAY bean. But I need to be able to change the background color based on another word or several discrete signals. I have an object which needs to read FAULT, RUN or OFF, and change colors to RED, GREEN, MAGENTA, or YELLOW based on the availability of the addressed devices. Can anyone help???? Quote
undercontrol Posted August 17, 2005 Report Posted August 17, 2005 Actually you could create applet yourself then put it in the frontpage, =S= has some examples which you could modify. Quote
