iQ Works Label objects Not showing In GT Designer 3 Project
Hi, I wonder if anyone has come across this problem before. I have a iQ works project using Labels. GT Designer 3 recognises them and allows me to assign them to objects without issues. It will also identify and allow me to reflect back to the database. The problem occurs if I use an object with a label, it does not appear at all on the GOT screen. If I swap back to defined M,D etc codes it is all fine. Any hints or tips ? Cheers Ian
Are you using Melsoft Navigator to keep the labels in sync? You must open both the PLC and the HMI from the same workspace in Navigator and follow the procedures to sync variables between the titles. It sounds to me like you didn't generate the routing information in the Navigator workspace. This step is required. MEAU has quick start guides on these topics. www.meau.com go to Downloads then Quick Start Guides.
I have exactly the same problem I have no errors everything is linked and routing generated but as you if I use x, y d etc in the Got it works fine but never if I use a label.
Did you sort it?
