udhaya Posted February 20, 2014 Report Posted February 20, 2014 Hi Friends, I'm using cp1h, cp1l,cj1h and cj1m type cpu's, i need to share some 10 data memory from Cp1h to all remaining cpu, is there any way to do this. help me...
kku Posted February 20, 2014 Report Posted February 20, 2014 I wonder if you can install the ethernet IP optional adatper on your CP1 PLC's (part number CP1W-EIP61). Then you can probably add a CJ1W-EIP21 card on your CJ1 PLC's. With these hopefully you can create a data link between all of them using Ethernet IP. This way you should be able to share data between them without doing too much work.
udhaya Posted February 21, 2014 Author Report Posted February 21, 2014 In Serial Rs 232 its not possible?
BITS N BYTES Posted February 21, 2014 Report Posted February 21, 2014 Use the built-in Serial PLC Link. Ideal for your application and easy to setup. Serial PLC Link.pdf
