Chris.Lyddiatt Posted March 19, 2014 Report Posted March 19, 2014 Hi everyone i'm new to this forum. I have a question about modifying a point table position through the HMI Our customer wants to be able to adjust the extend position via the HMI and im unsure if this is even possible with the equipment i have. We are using the FX3U-32MR/ES AC BASE UNIT, 16 DC IN / 16 RELAY OUTPUT PLC with the cc-link module FX3U-16CCL-M CC-LINK NETWORK MASTER (8 STA/ 8 ROI) the AMP we use is MR-J3-350T4 AMP 3.5KW 400V POINT TABLE CC-LINK and the servo is HF-JP3534BK 400V SRVMTR 3.5KW, BRK, KEYWAY(NO KEY) We use Melsoft Series MR Configurator2 amp software for the amp GT Designer3 for the HMI with a GOT1000 HMI on the equipment and we use GX Works2 to program in Ladder Any help would be greatly appreciated. Thank you
JRoss Posted March 20, 2014 Report Posted March 20, 2014 Sure. It's been a while since I used those cards, but as I recall you can modify the point table using the TO instruction. So have the user input the value to a standard register/s then use the TO instruction to pass them to the motion card.
