Hi Friends, Does anyone please know where i can download the Mitsubishi MX SHEET (for free) and How to transfer data from PLC to MX SHEET. I don't have any experience with MX SHEET. That will be great :) Thanks
Unfortunately i don't have enough budget to purchase it. Let me tell you my problem. There might be any other way to do it. I am using GX IEC Developer and HM1 (E-Designer 7.0). I have read different samples of the current data(from current sensor ACS712) and voltage data using Mitsubishi FX2N-4AD. I need to use this data to show it in the graphical form by comparing it with standard power to show the amount of spikes in the power supplied and to carry out power calculations like X(n)-X(N-1)/Ts. Its my first time. How shall i do it?. Can i do it using HMI to carry out these calculations? There is any option in Microsoft Excel to import data using SQL server but don't know if it will work or how will it work? Please help me anyone Thanks
MX Sheet would be nice for this since you don't need the power of a SQL database to process the data. However MX Sheet is still a component you need to purchase, contact your local Mitsu Dealer.
I studied the index files of HMI (E-designer) and also the Beijer manual, it is possible to do data logging with the E-Designer by using the trends. The data can even be observed in graphical form. Even the data transfer is possible in real time. The data can then be transferred using the HMI Tool Box by Beijer. The data can be transferred to the Excel sheet to carry out data analysis. If someone is struggling with the data logging or data transfer to Excel it is a good economical option instead of buying the MX component which nearly do the same job.
I agree, however remember that you have to manually export the files from E-Designer to any kind of software you would like to present the data on. There is a big difference in how E-Panels work and how MX Sheet works.
