seter Posted March 22, 2014 Report Posted March 22, 2014 Hello Everyone i will Provide the Q PLC System for DCS get the status in PLC Q00CPU (DCS it Master Modbus ), Now, i use the function of GX works 2 intelligent function by this it first time for me ! everyone can help for how to Setting this module?? Thanks
kaare_t Posted March 22, 2014 Report Posted March 22, 2014 What is your progress so far (what have you done)? Are you going to be a master or a slave?
seter Posted March 22, 2014 Author Report Posted March 22, 2014 The DCS System need to get data in PLC such as status Pump--- status Temp.. and Etc... i will setting PLC Q00 CPU with Qj71MB91 in Slave Mode but this module i never use it before. I want to know ? how to setting when use intelligent function in Software GXworks2
kaare_t Posted March 22, 2014 Report Posted March 22, 2014 For slave mode you only need to initialize the module with the correct baudrate and bit settings, and station number. Then the Master device can basically read out status from the PLC... Check the quick start in the manual and let us know if you run into problems...
seter Posted March 23, 2014 Author Report Posted March 23, 2014 Now it OK ,(Use Default Setting in Setting Modbus Device Assignment) the quick start for GXWorks 2 don't have only have gxdeverloper anyone have for gxwork2 ??? so it OK, i used the Kepware EX for read Modbus in QJ1MB91 Module and i can only read can not write in holdding register, i don't know Why ????? PS. i need link for manual this module configuration by gxworks 2!!!!!! Thanks.
kaare_t Posted March 23, 2014 Report Posted March 23, 2014 What are your switch settings in GX Developer for the module? You can download the manual from the Mitsu website. Just search for QJ71MB91...
