Guest John Crombie Posted September 14, 2004 Report Posted September 14, 2004 Hello All I am trying to perform a CClink between a Mitsubish A2ECPU with AJ61BT11 CClink module and an FX1n-24MR with FX2n-32CCL. I am not getting the CPU R/W light come up on the AJ61BT11 module and there is a diagnostic error in the ACPU (M9008 is on, D9008 = 50). Everything is ok at the FX end. Im using the buffer memory code in the ACPU and am getting D's transferred but not M's. Can anyone help. John Crombie john.crombie@az1.bp.com Quote
navillusi Posted September 14, 2004 Report Posted September 14, 2004 Can you post an example of the code you are using to set up the master station? Quote
Guest John Crombi Posted September 15, 2004 Report Posted September 15, 2004 Thanks I'll upload it when I get a chance John Crombie :-8 Quote
