H i i have a CP1W Ethernet IO module on an omron PLC. The LED "ERR" light is flashing. The PLC is connected to a PC constantly via this Ethernet board Connecting via the web interface i have seen that under the status view of the web interface the Address Disagreement parameter is abnormal. Looking at he manual it suggests the following: "Make sure that the node number and the last byte of the IP address are the same and then set other host ID's to 0. Change the address conversion method" if the PLC ip address is 172.25.0.94 does this mean that the fins node address should be set to 94?
Well ..... I haven't used that module but I believe the FINS node is HEX and the IP address is decimal. That means the node address must be converted to HEX. 94 decimal = 5E hex. At least that's the way it works with the CJ2M node switches.
