Dear Mr/ Ms, I have a Q02H CPU and GX works software. If I want to connect them and without SC-06 cable how can I do. But I have cable use for Omron PLC I can use for Mitsubishi? I can How can I download driver for cable? Please help me to slove this!!!! Best regards,
USB is USB. IT is NOT vendor specific. The driver is already on your machine if you installed the software. Follow the directions in the manual to install the USB driver once you plug in a USB cable. And SC06 is a SERIAL cable, not USB. The proper serial cable is QC30-R2 or in the US they have SC-Q.
Dear Mr/Ms, For that question I will answer as: Cable for programmer PLC not for touchscreen. I have already used Omron PLC program cable 4pin for PLC Q02H mitsubishi that work correctly and I program that now is OK. Cable R2 with USB that is another option for program QPLC. Mini usb cable use for HMI Thanks & best regards,
It's better to use USB. Buy a normal Printer USB cable, it will work. Once you plug in the cable, you might have to install driver from C:Melsec/Easysocket/USBDrivers.
