Arturas Posted June 20, 2014 Report Posted June 20, 2014 Hello, Is it possible to assign tag on the run? E.g. i have 2 buttons and input field, if i press button no.1 - tag1 is assigned to input field, if i press button no.2 - tag2 is assigned to input field. Tank you in advance /A Quote
Supporter Posted June 21, 2014 Report Posted June 21, 2014 Hi, iX has a feature called Alias that allows you to create instances of a screen. Each instance can be connected to separate/unique tags. This is however configured in the development software and not in runtime. There is a sample application included in iX Developer that shows and explains this feature. //Supporter 1 Quote
Arturas Posted June 21, 2014 Author Report Posted June 21, 2014 Thank you for the answer, i'll check it. /A Quote
Miften Posted June 24, 2014 Report Posted June 24, 2014 Or easier (or going around) You can play with visibility option - Button Press - Tag1 on field is visible next press Tag 2 on diffrent field is visible. M. Quote
Arturas Posted June 25, 2014 Author Report Posted June 25, 2014 Alias saved my day. @Miften. Well, there are to many tags so visibility is kind complicated. /A Quote
