Tom749 Posted June 20, 2014 Report Posted June 20, 2014 (edited) Hi, there. Can you explain about this attachment? At first read the #OB_SCAN_1 data, then compare 1 with that. After that the M0.5 set or reset to 1 or 0 following the RLO result. Is it right? Thanks for your help in advance. Edited June 20, 2014 by Tom749 Quote
