ianreeves Posted July 7, 2014 Report Posted July 7, 2014 Hi, Does anyone know if it's possible to display text at a defined X & Y position depending on a couple of Data Registers ? It's a standard item of text, I'd just like to move it around the screen. I'm using a GT1030 screen and GT Designer 3 v1.106L Thanks Quote
JRoss Posted July 7, 2014 Report Posted July 7, 2014 I don't believe you can control the position of the text directly, but you could put it on an "superimpose" window. It's similar to the "overlap" window, but it doesn't have the window frame, so it can appear as part of the main display if you set it up right. In the system settings, you can set registers to control the window, including position. There are two types of screens you can create. The Base screens are the normal displays. The Window screens can be sized smaller and used as either overlap (popup) or superimpose. Quote
ianreeves Posted July 8, 2014 Author Report Posted July 8, 2014 Cheers, that's my best bet. Make a borderless window and shift that around. One if those nice features I'd like to have, along with TrueType bit comments. Quote
