Oncloud9 Posted July 10, 2014 Report Posted July 10, 2014 I am a high school teacher and I am working to learn how to program using CX Programmer. I have CMP2C 20cdr-d PLCs. I am writing a program to use a sequence of 4 flashing lights to simulate energizing the fields in a stepper motor and using a counter to stop the sequence after 9 cycles. I programmed a start switch with a hold-over latch to begin the sequence and have programmed the CNT output to energize a LOAD NOT stop bit in each run. The counter counts down correctly to 0 but doesn't change the status of the stops. The start work bit turns on the first light and initiate the first timer. The timer correctly changes the LOAD NOT bit to turn off the first light and turns on the next rung. I have placed the sequence stop LOAD NOT bit in the start rung and in series with the timers on each rung. My final rung(excluding the end) uses the final timer output to cycle back to the first light in sequence. It does have the LOAD NOT bit addressed to the counter to turn off the start bit. There are two clues that I believe are significant but I have been unable to figure out a solution. The program starts immediately upon the RUN without the push button input and the counter doesn't stop the when O is reached. This tells me I have a loop. I tried removing the latch in the start bit rung but then needed to hold the push button for the program to work. How else might I initiate and stop the light sequence? Thank you for your help.
Jay Anthony Posted July 10, 2014 Report Posted July 10, 2014 Sounds like you have done an incredible amount of work for a beginner. Please post the .cxp file and we will all take a look at it. Or, if you do not want your students to find it, send it to me in a private email.
Oncloud9 Posted July 10, 2014 Author Report Posted July 10, 2014 I have attached the file. motorsimulate.cxp
IO_Rack Posted July 11, 2014 Report Posted July 11, 2014 I haven't tried to fully understand what you are trying to do but I will point out a couple of fundamental issues. - You are driving CNT 10 in rung 1 and using the contact of C100 in rung 2. The addresses do not match. - 20.02 is being used in duplicate output. It will always be evaluated by its last use before the END statement. Duplicate OUT statements are generally bad practice. If you would like to change its state in multiple places in the program, it is better to the SET and RSET instructions.
Oncloud9 Posted July 11, 2014 Author Report Posted July 11, 2014 Thanks for picking up the transposing of the counter number; sometimes can't see the tree when looking at the forest. Correcting this issue made the counter to do what I wanted. I also agree with the statement about the last use of bit 20.02. I am still trying to figure out how to allow the 4 light sequence to repeat without triggering the 20.02bit. I have tried DIFU and SET-RESET but was unable to solve the problem. I have repeatedly been going back to the manual after each failed attempt. It dawned on me this morning that the solution might involve using MOVE to relocate the start bit for each subsequent cycle one bit address to avoid duplicate start address and permit the push button start. Wish me luck.
IO_Rack Posted July 11, 2014 Report Posted July 11, 2014 It sounds to me like you require two separate signals. One signal to turn ON when Start is pressed then turn OFF when the count is done. You kinda have that one if you remove the duplicate output. A second signal is required to restart your timer sequence. You can use the completion of Timer 4 to do that. I have an example if you would like. I don't want to spoil it for you in case you want to figure it out.
Oncloud9 Posted July 12, 2014 Author Report Posted July 12, 2014 Doing the foxtrot: two steps forward - one step backwards...lol. Used SFT to create a separate start bit for each cycle with push button start as i wanted. Now realize I have to turn off timers 1through 4 and still working on it. I am interested in the solution you have as simpler is always better.
Oncloud9 Posted July 12, 2014 Author Report Posted July 12, 2014 UREKA !!! - I got program to work. Thank you very much for your help. Realized I needed to turn off only timer 1 by using force and program advanced to next cycle. Used timer 4 to energize a LOAD NOT stopping bit for timer 1. Used my start bit to SET-RSET the stopping bit.
Mendon Systems Posted July 12, 2014 Report Posted July 12, 2014 Glad to hear that you solved it !! More important .... you learned how to do it yourself!! It's amazing how many students come here (and the other forum) looking for someone to solve their homework problems for them. You are now qualified to teach problem solving to them.
IO_Rack Posted July 12, 2014 Report Posted July 12, 2014 Great work! My example was your original program modified exactly as you described above. Your shift register approach is not a bad idea. Though a little more complex, they can offer more flexibility. Good luck with your class and please feel free to come back with any more questions.
