antht Posted September 23, 2004 Report Posted September 23, 2004 I am currently trying to set-up a system to send data from data registers on my Q02 via a QJ71C24N to a PC. Someone has suggested using the G.OUPUT instruction which I have tried but it does not seem to work as well. I set-up a similar test system using an A1SJH and it worked ok. The data arrived in a hex format which is what I want. I basically want to do the same again using no-protocal mode. I am doing it the best way? Q_Server_Prog.doc
