Hello Guys, I've made a project in designer for NS8 using serial port host. But when I bought the NS8 I have bigger budget and then I bought the ethernet version. How can I change the host without changing all the objects in the project? I tried to create a new ethernet host and then delete the serial host but it is not allowed. Can you guys help me? Regards
Create the Ethernet host and give it a name. Then as IO_Rack said, use the replace host option. Once no objects are associated to the serial host, you should be able to delete it.
