Hi, anyone knows if there is a VNC program that will work on Windows XP embedded 2002 on a Beckhoff controller ? team viewer doesn't support Embedded or CE. maybe there is another solution? thanks!
Are you looking for a true VNC or something like Teamviewer that has an automatic web connect feature? UltraVNC or TightVNC should work, but you need to be able to ping the device using a VLAN or something of the sort first. If you're on the local network already then it's perfect.
