Hi there! I have CS1G-CPU42-V1 PLC and I have Cx_programmer V6. I want to connect the PLC/Program to my personal computer. So what type of cable should I use? Is this the type to be used? Does it normally comes with a cd driver? And do I have to identify the ports so my computer knows which input it is? << example photo only Please help me, experts. Thank you!
If you took the time to read manual W339 appendix E you will find that you require a special cable - the Omron RS232 port is not standard. You will also require a USB/RS232 converter to use with that cable - I would suggest you buy the Omron one - it is not cheap but it does work.
