robborsc Posted August 14, 2014 Report Posted August 14, 2014 Hi I am having a problem with an error/fault code. The fault comes from a lenze drive as an integer. We have a proface HMI monitoring a DBW in the siemens S7 300 that holds the lenze fault code. The PLC comes up with a generic code "lenze drive fault". The proface comes up with the drive code. I would like the PLC to produce a fault description using the lenze fault code in the DBW, instead of the generic one [listed above]. could anyone please help with this problem Thanks Robbo
