It is a FX mr48 using the dos ver. of medoc. Was just online a few days ago checking some things with no problem nothing has been done other the machine running I can't get in run till fault is cleared
That message indicates that a parameter setting in the project is not correct. Are you certain the program is configured for the right CPU type? Bot the FX and MEDOC are extremely out of date. Perhaps the PLC battery went dead and the PLC is blank? As it indicated, you can always try to clear all PLC memory and download your program again.
